tolien said:Edit: Looking around, that switch retails for...£939.99 inc VAT![]()
Energize said:Why do companies buy cisco things? If they cost that much then they are a rip off, im suprised their even allowed to sell things for that much.
eXSBass said:Bwuh ha ha ha ha! And the worrying thing is companies buy them.
AND CISCO LIKE IT!![]()
burbleflop said:Companies buy Cisco because it's the best you can get. The kit is reliable, upgradable, and feature packed. I wouldn't consider anything other than Cisco for the company.
Companies can set what ever pricing structure they like. You get what you pay for afterall.
"just as well and reliably" - sure?Energize said:I know that its the best but is it worth buying a 8 port cisco router for £900, when you can get ones that work just as well and reliably for £20, surely companies wouldnt want to spend so much money when they can spend hundreds less on something that is almost the same?
Beansprout said:"just as well and reliably" - sure?
Methinks you're a bit out of your depth re the corporate environment![]()
Energize said:Well Ive been using a £5 generic 8 port switch for 2 years and its never crashed once, so a £20 netgear one should be even better, I just dont see how something can be more reliable than that. If its a 8 port switch its only going to be a very small shop/office using it anyway so I dont see why they would pay £900 for one.
pdw8 said:newish supplier
Caged said:Not Foundry is it?
Skilldibop said:Companies use cisco because they are the most refined and well balanced on the market. The IOS is standardised so everyone knows how to use it.
They never break/stop. I've seen 2600s with uptime well in excess of 1000 days.
Where other companies produce the odd outstanding product, Cisco have entire series' that are tried and tested to be absolutely bullet proof.
The biggest selling point is the scalability of their products.
They also developed things like RIP and RIPv2 which are cisco propriatory dynamic routing protocols which can be used in addition to industry standards.
They just go one better than anyone else and so if it's mission critical it'll be Cisco.
