Citirx remote access
28 Dec 2002
South Coast
Does anybody else here use citirx to access work systems from home? Doe any of you have issues if you use it over wireless?
yep, i use citrix. it's fine over wireless. the ica protocol is optimised to be efficient over low bandwidth high latency connectivity. i believe we may even have a few people who *shudder* use it over dial-up!
Use Citrix both inside and outside a VPN tunnel from home over a wireless connection to my router. Works like a charm.
Have used it over dialup many times in the past and still occasionally over a GPRS data card.
If its dropping out, Citrix isn't your issue - you may have more fundamental problems with your wireless link.
Citrix works without a hitch for me on wireless at home and thats on 5 or 6 different servers/clients too.
Yep, got an Access Gateway set up here, have loads of people on home wifi using it including myself, not had any problems with it :) Great bit of kit, once you get it setup :eek:
Also use Citrix via a CAG. Works fine on wireless. Citrix only need about 34k to operate and should be fine on wireless and in some cases the likes of ISDN.
I'm not sure what version you use but there is an option in the one i use for session reliability that you can tick within the citrix options. I don't know why you wouldn't want a reliable session but there you go!:D
