Citreon DS4 where is the horn?
11 Jul 2011
Fixing the wifes DS4 the horn has stopped working thinking its just a new unit thats needed hopefully and nothing else to do with wiring.
I've looked under the bonnet but i don't see it. Wondering if its undernearth the bumper can anyone confirm?
Thanks.
Under the bumper passenger side I believe. Or so google tells me.
Ah i did google myself but everything came up DS3 thanks.
does it have its own fuse? I'd check that first depending on how old the DS4 is but this might help: https://fuse-box.info/citroen/citroen-ds4-2011-2018-fuses
Yeah changed it to no avail. I am hoping and praying its the horn itself has either coroded or came loose and just needs a changeover. Shouldn't cost more than £10 for a breakers yard.
