- 6 Oct 2006
- Luton
Are there any Citrix experts in here....
I have a problem installing office 200 on a PSe4 box on Windows server 2003.
Iam using the termsrv.mst from the office 2000 resource kit. i am running the following command:
The last is verbose logging to help with the problem. When tyhis command is run i get the following error:
Error applying transforms. Verify that the specified transform paths are valid.
I have tried various solutions from the net but have had no luck. Everything I do ends up with this error.
the contents of the verbose installation log is :
Thanks
Code:
C:\Office\SETUPSTD.EXE /Transform=c:\termsrvr.mst /l*v c:\officeinstall.txt
Does anybody have any ideas.....=== Verbose logging started: 12/06/2009 13:30:56 Build type: SHIP UNICODE 3.01.4000.4042 Calling process: C:\WINDOWS\system32\msiexec.exe ===
MSI (c) (B4:74) 13:30:56:563: Resetting cached policy values
MSI (c) (B4:74) 13:30:56:579: Machine policy value 'Debug' is 0
MSI (c) (B4:74) 13:30:56:579: ******* RunEngine:
******* Product: C:\Office\data1Std.msi
******* Action:
******* CommandLine: **********
MSI (c) (B4:74) 13:30:56:579: Machine policy value 'DisableUserInstalls' is 0
MSI (c) (B4:74) 13:30:56:594: SOFTWARE RESTRICTION POLICY: Verifying package --> 'C:\Office\data1Std.msi' against software restriction policy
MSI (c) (B4:74) 13:30:56:594: Note: 1: 2262 2: DigitalSignature 3: -2147287038
MSI (c) (B4:74) 13:30:56:594: SOFTWARE RESTRICTION POLICY: C:\Office\data1Std.msi is not digitally signed
MSI (c) (B4:74) 13:30:56:594: SOFTWARE RESTRICTION POLICY: C:\Office\data1Std.msi is permitted to run at the 'unrestricted' authorization level.
MSI (c) (B4:74) 13:30:56:610: Cloaking enabled.
MSI (c) (B4:74) 13:30:56:610: Attempting to enable all disabled priveleges before calling Install on Server
MSI (c) (B4:74) 13:30:56:625: End dialog not enabled
MSI (c) (B4:74) 13:30:56:625: Original package ==> C:\Office\data1Std.msi
MSI (c) (B4:74) 13:30:56:625: Package we're running from ==> C:\DOCUME~1\HEADHO~1\LOCALS~1\Temp\1\7128ee.msi
MSI (c) (B4:74) 13:30:56:657: APPCOMPAT: looking for appcompat database entry with ProductCode '{00020409-78E1-11D2-B60F-006097C998E7}'.
MSI (c) (B4:74) 13:30:56:657: APPCOMPAT: no matching ProductCode found in database.
MSI (c) (B4:74) 13:30:56:657: MSCOREE not loaded loading copy from system32
MSI (c) (B4:74) 13:30:56:657: Machine policy value 'TransformsSecure' is 1
MSI (c) (B4:74) 13:30:56:672: Note: 1: 2205 2: 3: MsiFileHash
MSI (c) (B4:74) 13:30:56:672: Machine policy value 'DisablePatch' is 0
MSI (c) (B4:74) 13:30:56:672: Machine policy value 'AllowLockdownPatch' is 0
MSI (c) (B4:74) 13:30:56:672: Machine policy value 'DisableLUAPatching' is 1
MSI (c) (B4:74) 13:30:56:672: Machine policy value 'DisableFlyWeightPatching' is 0
MSI (c) (B4:74) 13:30:56:672: Looking for secure file transform:
MSI (c) (B4:74) 13:30:56:672: Note: 1: 2343
MSI (c) (B4:74) 13:30:56:672: Unable to create a temp copy of transform ''.
MSI (c) (B4:74) 13:30:56:672: Note: 1: 2203 2: 3: -2147287037
MSI (c) (B4:74) 13:30:56:672: Couldn't find cached transform . Looking for it at the source.
MSI (c) (B4:74) 13:30:56:672: Resolving source.
MSI (c) (B4:74) 13:30:56:672: Resolving source to launched-from source.
MSI (c) (B4:74) 13:30:56:672: Setting launched-from source as last-used.
+MSI (c) (B4:74) 13:30:56:672: SOURCEDIR ==> C:\Office+
MSI (c) (B4:74) 13:30:56:672: SOURCEDIR product ==> {00020409-78E1-11D2-B60F-006097C998E7}
MSI (c) (B4:74) 13:30:56:672: Looking for secure file transform: C:\Office
termsrvr.mst
MSI (c) (B4:74) 13:30:56:672: Original transform ==> C:\Office
termsrvr.mst
MSI (c) (B4:74) 13:30:56:672: Transform we're running from ==> C:\DOCUME~1\HEADHO~1\LOCALS~1\Temp\1\7128ef.mst
MSI (c) (B4:74) 13:30:56:672: Found missing cached transform C:\Office
termsrvr.mst. Adding it to re-cache list.
MSI (c) (B4:74) 13:30:56:672: SOFTWARE RESTRICTION POLICY: Verifying transform --> 'C:\Office
termsrvr.mst' against software restriction policy
MSI (c) (B4:74) 13:30:56:672: Note: 1: 2262 2: DigitalSignature 3: -2147287038
MSI (c) (B4:74) 13:30:56:672: SOFTWARE RESTRICTION POLICY: C:\Office
termsrvr.mst is not digitally signed
termsrvr.mst is permitted to run at the 'unrestricted' authorization level.
MSI (c) (B4:74) 13:30:56:672: Validating transform 'C:\DOCUME~1\HEADHO~1\LOCALS~1\Temp\1\7128ef.mst' with validation bits 0x908
MSI (c) (B4:74) 13:30:56:672: Note: 1: 2760 2: C:\DOCUME~1\HEADHO~1\LOCALS~1\Temp\1\7128ef.mst 3: C:\DOCUME~1\HEADHO~1\LOCALS~1\Temp\1\7128ee.msi 4: {77470B12-4927-11D2-B5FE-006097C998E7} 5: {77470B14-4927-11D2-B5FE-006097C998E7}
MSI (c) (B4:74) 13:30:56:672: 1: 2760 2: C:\DOCUME~1\HEADHO~1\LOCALS~1\Temp\1\7128ef.mst 3: C:\DOCUME~1\HEADHO~1\LOCALS~1\Temp\1\7128ee.msi 4: {77470B12-4927-11D2-B5FE-006097C998E7} 5: {77470B14-4927-11D2-B5FE-006097C998E7}
MSI (c) (B4:74) 13:30:56:672: Note: 1: 2729
DEBUG: Error 2760: Transform C:\DOCUME~1\HEADHO~1\LOCALS~1\Temp\1\7128ef.mst invalid for package C:\DOCUME~1\HEADHO~1\LOCALS~1\Temp\1\7128ee.msi. Expected upgrade code {77470B12-4927-11D2-B5FE-006097C998E7}, found {77470B14-4927-11D2-B5FE-006097C998E7}.
C:\Office
termsrvr.mst
MSI (c) (B4:74) 13:30:56:672: Note: 1: 1708
MSI (c) (B4:74) 13:30:56:672: Product: Microsoft Office 2000 SR-1 Standard -- Installation failed.
MSI (c) (B4:74) 13:30:56:688: Attempting to delete file C:\DOCUME~1\HEADHO~1\LOCALS~1\Temp\1\7128ef.mst
MSI (c) (B4:74) 13:30:56:688: MainEngineThread is returning 1624
=== Verbose logging stopped: 12/06/2009 13:30:56 ===
Thanks
