Hey all,
The clutch has started to let go on the civic at 53k miles. Its currently only really in fourth and up but means the ability to accelerate hard has been removed as it just shows up as lovely clutch slip followed by a bit of grip and then more slip!.
There's a couple of options here and I'd appreciate some advice on which route to take
What would you guys do? Someone who works for ocuk had a civic clutch slip video up here not too long ago and that's exactly the same thing that I'm experiencing!
- Take it to Honda dealers and hope that its the pressure plate at fault. This is a common problem with the 2.2 and as long as the clutch itself is showing plenty of friction material HUK are pretty good at covering the cost. Concern here however, is that they may say - No sir its wear and tear and foot me with a massive bill
- Buy a revised 325 clutch and flywheel and get them fitted at my usual Indy garage. Labour is cheap there and the whole lot should cost a reasonable amount less than if Honda deem it to be driver fault and not the design fault.
- Buy an uprated clutch and a single mass flywheel. The cost of this kit is slightly less than the HUK clutch and DMF kit and allows for a lot more than standard power (perhaps a remap to go with this option)
