Hi all,
Bit of a shot in the dark but I'm wondering if anyone else has encountered this issue or similar with honda head units; Just fitted a new battery to my wife's 63 reg civic 1.8 petrol but now the radio is locked.
it appears to be this head unit
https://www.youtube.com/watch?v=5mnDxx1qPaI
When you start the car it just says that the anti theft has been enabled and to enter a 4 digit code, we had a good look through all the paperwork and found a security card which has a blank space for a security code and a serial number under it which is 5 or 6 letters which we can't enter into the unit as it only wants numbers.
I've been looking through various forums and Facebook groups which seem to indicate that the head unit should be VIN locked to the car, and to just hold down the power button to make it reboot and check back with the ECU, however pressing the power button on our head unit has zero effect, it just stays on all the time asking for a code.
I found the manual
https://www.honda.co.uk/content/dam... Owners/manuals/EN-SD-owner-manual-119391.pdf
Page 37, in conjunction with some other forums has me worried, I'm starting to get the impression that the previous owner may have set an anti-theft pin which has now been triggered, and that the solution seems to be that the head unit has to come out and get sent to the manufacturer "Clarion" to be factory reset (which just so happens to be in France is is probably going to cost £££££!)
I'm going to try contacting the local main dealer tomorrow unless anyone has a magic solution or knows how to find the code easily?
I found the manual
