Civic Type-R common faults (EP3)
16 Jan 2003
Kirkcaldy, Scotland
My mate is wanting to buy an EP3 civic type-r. What common faults are their with the Civic that he should look out for?
Cheers
condensation / misted up front headlights
The silver rubbing off the dash and door handles on the inside (VERY common)
Steering rack (theres a lot of EP3's that have had to have the steering rack replaced)
Just tell him to get a facelift (2004 onwards), so any problems will be fixed under warranty.
My warranty runs out in may so its booked in this wednesday for:
-Passenger side window rattle
-Drivers side air vent rattle
-Drivers side pillar rattle
Other than interior rattles there isn't much that goes wrong with them. Steering rack failures on facelifts are rare.
James_N said:
ah yeah, the front windows rattle like hell when they arent all the way down or all the way up. VERY annoying :(
Annoying as hell when I used to smoke but quit now :D
As already said, the only main issue is the steering rack.
There can also be issues with 2nd gear crunching
I found the Honda dealers would do anything to wriggle out of warrany work. It's for that reason I doubt I'll buy another, cos it was real hard work getting them to admit that there were any faults. I even ended up taking a 12 page thread from the Honda forum with dozens of people that had the same issue in order to get them to admit that there was a fault.
Yeh, Got a little line running down the side where it has rubbed off.
If you mean door card, I have that too when im banging out the tunes ;) :D
Other than that mine seems ok, 2004 CTR
No my door cards are fine, it's the A-pillar, it stops rattling (for a while) if you pull out the cup holder:p
Bloody rattles:)
