** Clean CSQ Supremacy Nickel & New Design Pump **
rjk
rjk
Caporegime
8 Aug 2007
Hi Guys
We have available for pre order now, the new clean design ultimate supremacy block from EK.
along with a new and improved design for the EK Pump units meaning it can be mounted in even more useful ways inside a case.
Ideal!
EK Water Blocks EK-Supremacy Clean CSQ - Full Nickel @ £64.99 inc VAT
This is a Clean CSQ variant of EK-Supremacy with the only difference being redesigned top.
EK-Supremacy is a result of round clock development, years of experience and rigorous testing. As a new EK flagship this product again combines top hydraulic and thermal performance.
EK-Supremacy is exactly the same as EK-Supremacy only with new design of the top.
EK-Supremacy is a universal CPU water block that fits all modern CPU sockets with a universal mounting mechanism that offers error-preventing, tool-less installation. The result is a perfect installation which results in perfect performance every time. EK-Supremacy is truly the best product for performance seeking enthusiasts.
EK-Supremacy is a successor of the legendary EK-Supreme HF water block launched in 2010. It's main improvements are:
- better hydraulic performance: due to improved design up to 20% higher flow compared to EK-Supreme HF
- better cooling performance: up to 2°C lower CPU temperatures compared to EK-Supreme HF
The EK-Supremacy cooling engine uses similar, yet refined as per needs of modern microprocessors, fin design as its ancestor. The cooling liquid accelerates through jet plate's nozzle and turbulently continues its path through numerous very thin channels which provide extreme cooling surface area. Specifically designed and carefully machined copper base (sometimes referred to as ‘cold plate’) is made from purest copper available on the market and is further polished to absolute mirror finish. This alone greatly improves the cooling performance of EK-Supremacy. The top itself is made of CNC machined nickel plated brass.
EK-Supremacy is also the first CPU water block on the market which has been optimized for every modern CPU platform independently with the use of different type of jet plates to ensure the best contact with the CPU integrated heat spreader (IHS). These jet plates of different shape and thickness are enclosed with the product.
Hybrid Thermal Solution: ready for air and water cooling: Featuring sharp ROG design, the Hybrid Thermal Solution heatsink integrates a 100% copper heatpipe and a water cooling channel with electroplated barb fittings to prepare you for air and water cooling. Boost heat removal from CPU VRMs, and achieve the overclocking and gaming stability advantage with double the flexibility.
CPU socket compatibility:
- Intel LGA-775
- Intel LGA-1155/1156
- Intel LGA-1366
- Intel LGA 2011
- AMD Sockets: 939, 754, 940
- AMD Sockets: AM2, AM2+, AM3, AM3+
Enclosed in the box:
- EK-Supremacy Clean CSQ series water block
- EK-CPU Precise Mount mounting mechanism
- EK-Supremacy Backplate system (Intel LGA-1366 & AMD AMx Backplate; Intel LGA-115x Backplate ; rubber gasket)
- Additional AMD Socket mounting plate
- TIM / thermal grease: Gelid GC-Extreme (EKWB 1.6g)
CAUTION:
- Narrow server type LGA-2011 is not supported by default – a Mounting plate Supremacy LGA-2011 Narrow ILM is mandatory to install this water block on narrow server type LGA-2011 motherboards.
Only £64.99 inc VAT.
ORDER NOW
EK Water Blocks EK-DCP 2.2 X-RES (incl. pump) @ £65.99 inc VAT
EK-DCP 2.2 X-RES is Combo Reservoir Unit bundled with EK-DCP 2.2, small but powerful 12V DC pump. The product is a direct successor of EK-Reservoir Combo DCP 2.2. This reservoir does not serve as a stanalone unit and can only be used with EK-DCP 2.2 water pump!
EK-DCP 2.2 X-RES is a compact, easy to use water pump/reservoir combo unit. Base and top of reservoir is made of quality POM Acetal while the clear tube is made of quality casted acrylic material. The reservoir has build-in port for installation of EK-DCP 2.2 water pump. This reservoir is fully air- and waterproof once closed with the enclosed plugs therefore no water can evaporate.
This reservoir also features vibration dampening rubber mounting system which effectively silents your computer.
The EK-DCP 2.2 water pump is the ideal solution for all enthusiast built water cooling systems and is compatible with the all standard water cooling system setups. The EK-DCP 2.2 will can achieve up to 400L / hour with its compact, powerful, low-noise and extremely reliable design.
Features:
- Compact design
- All-in-one unit: Reservoir + Pump in a single unit
- Factory pre-installed pump
- Vibration dampening design
- Monitor your water coolant level
- Easy installation
Specifications:
- main body size: 60x105x60mm (LxHxD)
- port threading: G1/4" x 2
- filling port: Acetal top
- main reservoir material: POM Acetal (black)
- includes needed Allen keys (6mm and 2mm) and 2x G1/4" plug
- includes classic metal mounting plate
- BONUS: includes 120mm fan mounting plate
Made in Slovenia - Europe!
Pump made in Taiwan!
Only £65.99 inc VAT.
ORDER NOW
Ah the upgrade from my full nickel supreme has arrived :D:D
Might just have to buy one for when IB-E arrives ;)
