Time to turn on the heating and so far I found a weeping compression joint which I fixed, It must have been leaking for years un noticed
Then the boiler pressure keep dropping, after long investigation there is no leak with all my radiators so water must be venting out within the boiler. Opened it up and found the expansion vessel has zero pressure, drained it and try pumping air in and it will not give. After a lot of effort the valve seems to loosen and air can get in and I managed to pressured it to 0.8 bar as stated on the side and all good now for days with no more dropping pressure and stable at 1.5-1.8 bar in operation.
While working on the boiler I decided to clean out the filter for the very first time...(installed on recommendation from BS 5 years ago) then OMG
Added inhibitor and put clean filter back, all heating working perfect for last 2 days but turned thermostat way down to 15c to save on gas
what a winter it will be
that's a lot of crud that would otherwise be sat at the bottom of a radiator or somewhere in the system. I presume you're going to check it a lot more often now?
Most filters you can check and clean without draining the system, I'd think yours is the same. I've fitted one to my system but less than 2 weeks ago I think so it won't have collected much.
