Cleaning a cloth mousemat?
17 Feb 2009
Leeds
How do you folks go about it? Just soap and water jobbie and hang it out to dry?
Anyone got any tips or tricks?
I tend to get a bowl of luke warm water, sponge and a bit of cleaning material e.g. liquid soap.
1. Put the sponge into the bowl, squeeze off any excess water and just wipe down the mouse mat.
2. Do the same this time but just with the soap/liquid soap.
3. Repeat step one.
4. Leave it to dry.
5. Done.
I put mine (Razer Goliathus) in the bottom of the bath, sprayed it with the shower head, squirted a small amount of washing up liquid on it, scrubbed with a nail brush, rinsed and left it to dry... Came out as good as new :-)
Not had to properly clean my new one yet (cant remember what its called, its big and smooth tho ha), vacuum worked well for dust tho.
