Well i just made a bowl of hot water bit of fairy liquid and gave it a good scrub, just towel dried it and put it on a radiator to dry, i shall let know know if it shrinks
Vacuum any bits off and then use warm water with a dish cloth to gently rub off any dirt. Had to clean mine last summer and i left them in the sun to dry, don't think you'll be able to do that bit though They came up as good as new though and if you do it right they don't fray.
its almost a daft question but ive thought of it too!!, ive got the boogie bug XL and often thought shall i just put in washing machine.....but what if......might give it ago anyway and see!!
