Cleaning advice
1 Aug 2006
I have had to empty my watercoolong loop after 8 weeks due to a build up of cloudy stringy white stuff in the res. (algae maybe) I thought I would not need to add any anti-algae stuff due to using ZEREZ racing coolant.
So my questions are as follows.
What is the best anti-algae stuff (would I be okay going into my local tropical fish dealer and getting something they recommend?)
What is a good additive to use that i can get from a high street store to mix with de-ionised water (anti-freeze?)
And lastly i was thinking about using a weak solution of miltons baby fluid and de-ionised water to clean and flush the system can anyone think of any negatives to this idea as it's safe on rubber teats and babies so I can't see it doing any damage to the pump or rads surely?
Thanks for the help guys
