- 18 Oct 2002
My alternator has started giving me some problems.
1994 306 DTurbo
I thought the battery was dying, and it went quite suddenly on the motorway @ 6 am on my way to get a flight from Manchester (I'm in Nottingham).
Anyway, called out the AA and it turns out its the alternator. The guy did the old hammer + alternator trick and that got it going again.
The question is, what shall I do?
Service current alternator? (I can take it off, but then what? I don't fancy taking it apart - can I just put it in the bath or something?
Get one from a scrappy? (Won't this be just as bad since I won't know how good it is?)
Get a brand new one? (£100 + VAT - ouch, but at least it should last)
I plan on having the car for as long as it's economical to run (hopefully some time yet!).
Thanks.
1994 306 DTurbo
)Get one from a scrappy? (Won't this be just as bad since I won't know how good it is?)
Thanks.
As you say, if you intend on keeping the car, maybe invest in a new one.
