Mohinder said:Every minute you spend cleaning it could be spent driving it.
[TW]Fox said:If you get free petrol.
zetec452 said:carwash ***.![]()
Mohinder said:As far as I know, super resin polish isn't actually an abrasive, proper polish, I think it fills scratches with resin as opposed to bringing the level of the paint down. Any abrasive in it is very very mild. I'd never polish it every time anyway, should have mentioned that really.
ethos said:Well so far on the list i've put:
Eurow X Large Waffle Weave Microfibre Drying Towel - 26" x 36"
Eurow Medium Waffle Weave Microfibre Drying Towel - 17" x 24"
Meguiars NXT Generation Car Wash
Meguiars NXT Generation Tech Wax
Meguiars Lambswool Wash Mitt
Which comes to £54![]()
That's without whatever I need to apply the wax, what would I use for that?
Gibbo said:Hi there
Yes those Eurow Large waffle weave towels are fantastic, I can dry my car using the large one in less than 5 minutes using a simple patting technique and I get no water marks.
The only thing I'd change would be the wax, get some collonite 476s as it much harder wearing, last time my car was waxed was February/March and it still shines and has good wax coating now as can be seen from recent photos I've taken.
wohoo said:One drying cloth is enough tbh,get the smaller microfibres from supermarkets, and yeah get a decent wax,harley,collinite 476/915,poor boys etc.
Id get some clay for good measure too.
It might be 54 notes but the stuff will last for 2-3 years.
My tub of colli 915 was £20 but i have done 5 cars with it, and i still have 3/4 of the tub left.
