Hey all,
Just another quick one,
After fixing my leaking sun roof on my clio, I am looking to remove the damp marks from the front seats and roof and was wondering the best way to do so!
It also has a very apparent smell of mould when you first get in the car, whats the best way to cure this?
Was thinking clean it with something then use a hair dryer to remove all the moisture?
Any advice,
Thanks, Sam
Any advice,
Thanks, Sam
