Hi,
Wasn't sure where to post this, think it fits in best here as it is to do with cleaning your general hardware
What do you guys use, if you have a very dusty PC from a friend/family member, that you've been asked to clean ... Specifically to clean the motherboard and PCI cards
Compressed air doesn't work as the dust is so baked on and there is so much of it that it need some 'contact', and obviously lint free tissues just get ripped on the legs of the components etc
I was wondering is there some soft brush that could be used that wouldn't get 'caught' on the component legs etc? I have a feeling someone will suggest a clean paintbrush but I'm not sure
What do you do then?
Thanks!
Thanks!
