Cleaning computer
1 Feb 2004
Hey all
I've got the Be Quiet Dark base pro 900 orange and Asus PB287Q 28inch 4k monitor, I just wondered the best cleaning materials to use for these are?. Just a microfibre cloth?, what about cleaning the tempered glass?
Thanks all
yeah microfibre for the glass, i would use hairdryer to blow out any dust inside the case/monitor first then use microfibre. in terms of cleaning liquid etc, i just use normal antibacterial wipes lol does the trick
Thanks all, how about using a microfibre sponge for cleaning dust off the screen?, or should I buy special wipes like previously mentioned?
