Deleted member 61728
Hi without using specialist cleaner to clean the cpu hs what can you use that is normaly lying around to get the artic silver offf the HS and make a nice contact ?
what kind of polish ?spit n polish
Nail Polish remover - works a treat
Many contain perfumes which leave residue, impeding the effectiveness of the thermal compound.
Hi Tron, I meant polish as in manual labour polish (rub rub rub).what kind of polish ?
I use isopropyl alcohol
^^ same here, cheap and v effective
