Cleaning EGR
1 Dec 2004
S.Wales
Hi all,
Just a quick question really, I am due to clean out the EGR valve again, tackled this a couple of years ago, last time I used a can of spray carb cleaner, and a lot of elbow grease, was wondering is there a preferred method of getting the liquid stuff and pouring it in a container, and placing the EGR value in and letting it soak for a while before trying to get all the crud out?
BMW 320D E90 is the car,
I believe Wynns EGR cleaner is better suited to removing the carbon deposits than carb cleaner, but the last time I cleaned an EGR I did it the manual way, as you describe.
Im going to have a nosey in halfords and eurocarparts tomorrow I think for the cleaning agent.
Need something stronger than a toothbrush this time :p
I was using a toothbrush and a big flathead.
Some sort of wire brush I think will be good
Don't use **** fuels, I run my Mondeo MK3 TDCi on V-Power, a waste of money some say but I removed the EGR after 85k when a boost hose split and it was pretty clean.
I got it shiny with a cap full of engine degreaser and an old toothbrush.
Italian tune up?
I tried a can of Wynn's, the stuff you spray into the intake, to clean the EGR valve on our XTrail when it threw a fault code for the valve being stuck open. It worked for a bit, but the EML light eventually returned. A good hard thrash along the motorway saw it cleared up for good though.
Just got some carb cleaner for £3.50 and a wire brush set (slightly larger version of a toothbrush) with wires on the end.
Yeh I know I should use good fuel really. I have been running up and down motorway over the last week.
Run out of cleaner, but here are the results, it wasnt as messy as I thought it would be, I was expecting a lot more in 2 years and running on not the best fuel.
Below was 2 years ago before I had given its first EGR clean in my ownership
Was going to take the MAF sensor off, as I have been reading up on that, and giving it a clean, people clean the actual MAF enclosure, but the important (and delecate thing) is a wire inside which is the actual sensor, and needs to be cleaned carefully with a cue tip or tip of some sort with a delicate cloth and some maf cleaner? anyone done this?
I usually just spray them liberally with electrical contact cleaner then allow them to dry, rather than touch the wires inside. The cars I've done this on though, I don't think were suffering particular problems with the MAF - I just did it when servicing them. So hard to tell if it had any effect.
Cracking job on that EGR by the way. I wanted to take it off our X-Trail and do something similar, but it was so inaccessible, I ended up just booting the throttle wide open on the motorway when the engine was nice and hot. Seemed to do the trick - nice big cloud of black smoke, and the engine management light never returned :D
Cheers :) yeh i used a single can of carb cleaner with that and a wire brush. There was still a little bit there. I may try the petrol bath method next time if i ever have to clean an EGR.
Re maf
Yeh will go with that i think, although its the wire bit that needs the clean. I have been told elec contact cleaner, Or carb cleaner. Probably won't touch it if i do find it. I will just give it a spray and let it dry, need to read up more on it
