Cleaning Engine Bay/Block
22 May 2003
Wigan
Should have my block out soon so can give the engine bay a quick once over, im thinking use GUNK or similar degreasant in oily spots and then just car shampoo and water to clean most of the crud off.
Then just Gunk or something on a rag to wipe over the block to get most of the crud off it?
Anything else useful i could use/advice (apart from dont drop the block on my toes! :p )
