- 12 Feb 2006
- Surrey
From the use of LogMeIn i can finally access my girlfriends Pc to clean it out and get her some new software to improve it
My plan so far is to get rid of norton and replace with avast and AVG, get Adaware and spybot. Also put firefox on and set that to default browers, get some extensions etc for it too.
Also going to check what services are running but not going to change much in there as im still new to what services are which and i know she'll kill me if i screw something up on her PC
Is there anything else i can do to clean it up and anything else i should put on it?
Also how do i remove Norton, and norton internet; do i just go add/remove software and remove it from there or is there more i need to do to get rid of it, such as in services etc?
think that was all i needed
thanks
thanks
