Cleaning H80 and GPU
25 Nov 2011
The KOP
Hello out of all my PC parts theses two are really hard to clean. On my H80 I take first fan off and stick a hoover onto it, but dust still stays there? Whats the best way on cleaning out dust on this without taking it out system and running under tap water.
Now Gpu heat sink I haven't touched am just wondering how do you guys clean yours?
Thanks
Compressed air cans for me.
Thanks I did pick up a can from another site, but when using on my keyboard as a test it now and then left a stain mark?
So didn't feel safe touching PC with it, Maybe because it was cheap lol or do all compressed air cans do this?
Witch one do you own?
Thanks again.
Thanks again.
Sounds like you aren't holding it upright or have shaken it first. There should be nothing but air sprayed out.
My recommendation is a small bed pump with a tiny nozzle, works a treat and can be had for cheap on the bay.
Yer no I do hold up right and have shaken very well before use. It sprays air and then it will randomly spray white stuff out lol
And that is a very good idea :) use a strong bike pump of some sort
Thanks
Your one use the mains for power? or is it just hand held?
Any pics if you could?
Thanks
