Hi all,
I have been using an Arctic Cooling Freezer 7 Pro rev 2 on my 775 socket chip for 6 months now.
And today Ive had delivered a new motherboard and i7 chip. I want to reuse my arctic because Ive heard that it'll be better than the stock heatsink.
When I first opened it up (the heatsink), it already have thermal stuff applied to it in a very neat square.
So I wondered if anyone knew if that is thermal grease, or thermal compound, or thermal tape?
If its a thermal tape, does that mean I dont need to clean it. I can reuse it?
And will any normal heatsink cleaner remove it?
And lastly, just before I run down to the local electrical store, what should I buy?
thermal grease?
thermal compound?
thermal tape?
(at some point I do want to play with overclocking)
thermal grease?
thermal compound?
thermal tape?
