Cleaning heatsink
19 May 2020
Hi All,
Quick question, I am not sure if this is already mentioned somewhere. I couldnt find it. I have the CPU fan below.
COOLER MASTER MASTERLIQUID ML120R
After using it for 8 months or so, I can see there is a little build up of dust in the heatsink inbetween the fans. I am guessing this is relatively normal, and its going to need to be a lot more serious before the perfomance is affected.
However, it led me to wonder, is it worth taking it off, cleaning and replacing, or just buy a new one and replace?
Appologies if this is covered somewhere else or in the wrong place.
Thanks in advance,
Kris
Yes that's "normal". What's the fan set up inside your case? do you have more air being pulled in (fans on the front), than being pushed out (at the back/top)? if so then that's positive pressure and air/dust wont be being pulled in via gaps in the case, only through the front fans. if you have positive pressure, you can add a dust grill to those front fans.
Yes, there are three fans at the front pulling air in, and the one at the back, plus just a vent at the top, so I will do that.
Best with compressed air is to blow air in opposite direction of what fan flows air. With compressed air is pushing out dust and lint the opposite direction fan has pushed it in instead of just push it in tighter. Hope that makes sense.
ah yes, that makes sense!
