Cleaning inside of windscreen
4 Dec 2002
Bourne, Lincs
I need to clean the inside of my windscreen as it keeps steaming up and there is some gunk on there, what would be the best thing to use?
Cheers
Kimbie
Do it with a vinegar based glass cleaner, and a cloth. Then leave it for 5mins to dry off and get a clean dry microfibre cloth and dry wipe it(nothing on the window or cloth), this gets rid of the smears left behind and your windscreen will be crystal clear.
Just clean it, and DONT PUT YOUR FINGERS ON IT EVER!
Then it will de-fog in seconds, and always be clean!
As soon as you start smearing your fingers all over it, game over. :(
