Cleaning out the dust n crud
  • Thread starter Thread starter noj
  • Start date Start date
noj
noj
10 Nov 2011
Devon
Curious what people use to clean out the dust and crud from the inside of their rigs. For me its a combination of cotton buds and a very soft toothbrush to get round the fan blades and a microfibre cloth to wipe round the other surfaces.
It mostly does the job but hard to get to every surface
Even with filters I regularly clean out the PC still fills up with crud after a while.
i was worried that the static from the end of the hoover could be bad so never tried it.
THIS:
DATAVAC 500W - it's a beast
And a paintbrush to clean fan fins.
Have to agree with ripshod - discovered how useful a paint brush can be when cleaning out dust around and on fans etc - very convenient.
I use a small paint brush and a vacuum to get the surface dust off, then use a cheap mains inflator for air beds/toys to blow the rest out.
It removes a lot more dust out than just the vacuum.
Same here.every now and again(or before working on anyones pc)into the garage fire up the compressor and 120psi of cleanliness :D
I used to work for a car dealership and using their airlines to clean out PC's was awesome! :D Looked good as new after a couple of blasts! :D
Its shocking how much dust accumulates in GPU's and radiators :eek: The air line just gets everything spotless with no risk of static and its so quick and easy.
The assemblers don't like it when I bring stuff to their dept and use the air lines, I do it anyway though because its free air!
