anti-static brushes around the fans etc.
alcohol free. Is this ok to use?
Cheers.
Recently purchased one of those, great little thing. I just use a small paint brush for the fans and then alcohol wipes for the tempered glass.How often do you dust the inside? I just purchased the CompuCleaner off amazon as I've never really liked using canned air, at the moment every month or so I'm just giving it a blast inside and using anti-static brushes around the fans etc.
This will work fine. A lint free cloth is the best.Hi guys,
What does everyone use to clean their PC case window? Currently I'm just using cleaning tissues that I use to clean my laptop screen and keyboard, they're alcohol free. Is this ok to use?
Cheers.
Yeh, sure that's what you use those tissues for.
Tingly tip!
