Cleaning PC K62...?
2 Jul 2010
Okay, so I haven't really looked after my case as much as I should and it's beginning to build up dust inside and out. The front panel and panel on top of the case are detachable. So long as I remove the dust filters from the front panel, would it be okay to just 'wash' the panels in water? I'm presuming it will be, but I just want to make sure as I'd hate to end up with it looking worst than what it does now. To get the dust out from inside the case, I'm presuming hoovering it would clean most of the dust? If not, I'm presuming a can of compressed air will be needed.
I can't see why you can't wash the panels. compressed air is great. I also use a smallish paint brush to reach in and nudge stubborn bits- mostly on fans.
Done this myself with that case many times, you will be fine as long as you remember to let the panels dry before you put them back on ;)
