12 Feb 2006 at 17:10 #1 gaz1234 gaz1234 Associate Joined 29 Dec 2005 Posts 229 Ok, so what is the best cleaning (shampoo, polish) product to go for?? I personally used Autoglim. I've been told that Zymol is the best!? thanks
12 Feb 2006 at 17:33 #2 xcessive xcessive Associate Joined 28 Jul 2003 Posts 1,548 Location kent Meguiars. The best stuff i've used.
12 Feb 2006 at 18:05 #3 Muncher Muncher Soldato Joined 17 Oct 2002 Posts 7,169 Location Ipswich Zymol comes highly recommened and in terms of high end waxes it has the biggest market share, and is up to £5,800 per pot. I've not used Zymol before but I don't think you can go wrong with it, if you avoid their really cheap stuff.
12 Feb 2006 at 18:06 #4 thedazman67 thedazman67 Associate Joined 24 Apr 2004 Posts 2,055 Location Warrington, UK Meguiars for me as well. thedazman
