Hello all,
Today I have my radiators being delivered, I still need to get some distilled/de-ionised water to clean the rads.
I've looked on Halfords website and the only thing I found was 'Halfords Battery Top-Up Water 5L' it states
Would this be fine to use for cleaning my new rads?
I did check Tesco’s website but couldn’t find anything, they either must have stopped listing it on their website or stopped selling it.
Here is the Halfords link so you can take a look.
I will be using Mayhems Pre-Mix for the coolant so this is just for cleaning the radiator's, Would this Halfords stuff be fine?
Many thanks,
Dons: I don’t think this is classed as a competitor, if it is please remove this thread.
The Halfords Battery Top-Up Water is a 5 litre bottle of de-ionised water, suitable for use in lead-acid batteries. It can also be used in engine cooling systems to reduce scaling and corrosion as well as irons, lava lamps and air-conditioning units.
Many thanks,
