Cleaning remote membranes - best technique (IPA/servisol/...)
1 Mar 2010
What do you do for cleaning the touchpad membranes on remotes when they become intermittent ?
I understand they are rubber impregnated with carbon/conductive particles.
I used to use IPA, which I still use with a q-tip on the circuit board, but for the membrane, I think (like for windscreen wipers) it can remove the flexibility/destroy the rubber,
so I have used servisol switch cleaner (like for volume control/pots), or foaming type/bomb cleaners applied, also, with a Q-tip
That's a humax remote, the panasonic tv one never has an issue.
I even tried rubbing the membrane with a soft lead pencil at one point.
OK - hadn't realised there was much variation in design, until you had some kind of mechanical key with metal contacts,
and thought it was just down to some variation of quality of membrane / button size that might explain why my panasonic tv remote did not yet require an intervention,
unlike humax/philips/siemens-dect
Many years ago I worked in a small TV repair shop. If the contacts on the membrane lost their conductivity then my boss would cut little squares of the foil wrapper in a cigarette packet and stick them on, always seemed to do the trick.
