- 24 May 2004
Ive noticed the eclipse / pec-pad combination mentioned here as a prefered choice when cleaning the filter plate that sits infront of the sensor on dSLRs. Does this mean you make your own spatula that you wrap the pec-pads around? or can you use some stiff paper?
Would you use the 'blow through a thin straw' approach to moving dust particles?
