18 Jul 2006 at 05:08 #1 Dorian Dorian Associate Joined 9 Apr 2006 Posts 15 Location Lost in the Milky Way Whats the best solution/wipes for cleaning TFT monitors without damaging them..
18 Jul 2006 at 08:02 #2 Kreeeee Kreeeee Man of Honour Joined 13 Jul 2004 Posts 44,092 Location /* */ Don't. Use a microfibre cloth and no liquids should be necessary unless you spat on your monitor. Dust just wipes off.
18 Jul 2006 at 09:23 #3 Yabsley Yabsley Associate Joined 25 Apr 2006 Posts 202 Kreeeee said: Don't. Use a microfibre cloth and no liquids should be necessary unless you spat on your monitor. Dust just wipes off. Click to expand... How do you know what is and what isn't a microfibre cloth?
18 Jul 2006 at 09:45 #4 PinkFloyd PinkFloyd Soldato Joined 21 Sep 2005 Posts 14,941 Location Bradley Stoke, Bristol afaik microfibre cloth would be something that doesn't leave bits of itself on the screen. for example a tissue will leave lint over a screen. I use a slightly dampened bit of lint free cloth
18 Jul 2006 at 09:45 #5 VaderDSL VaderDSL Soldato Joined 18 Oct 2002 Posts 16,557 Location Manchester I use my glasses cleaning spray and my pentax cleaning cloth
18 Jul 2006 at 11:12 #6 Kreeeee Kreeeee Man of Honour Joined 13 Jul 2004 Posts 44,092 Location /* */ Microfibre cloths are lint free. Glasses cloths are a good example of them.
18 Jul 2006 at 21:29 #7 Dorian Dorian Associate OP Joined 9 Apr 2006 Posts 15 Location Lost in the Milky Way Magic, Thanks for the feedback. Sounds like time to raid the wifes glasses case.......
