5 Feb 2014 at 08:26 #1 Nickolp1974 Nickolp1974 Soldato Joined 15 May 2012 Posts 5,934 Location Louth, lincs When i first got my lian li d600 i peeled off the protective film from the window but its left a residue, how can i clean this off??
5 Feb 2014 at 10:21 #2 setter setter Caporegime Joined 14 Dec 2005 Posts 28,067 Location armoy, n. ireland Try a drop of methylated spirit on a lint free cloth.
9 Feb 2014 at 21:32 #3 chaparral chaparral Caporegime Joined 27 Nov 2005 Posts 25,749 Location Guernsey Have you tried using just a cloth damped with just plain water ??
9 Feb 2014 at 22:50 #4 The Matrix The Matrix Associate Joined 12 Jul 2012 Posts 992 99% isopropyl alcohol should remove the residue off the window, it doesn't leave streaks. Use a lint free cloth.
9 Feb 2014 at 22:59 #5 Wizzfizz Wizzfizz Soldato Joined 13 Oct 2003 Posts 10,839 Location Left of the middle I use alcohol wipes that are meant for cleaning specs. Does the job fine and can be bought for a £1 for 30 in the pound shop.
9 Feb 2014 at 23:32 #6 Something Else Something Else Soldato Joined 19 Feb 2012 Posts 4,409 If it is a perspex window it will be scratched no matter what you use to clean it. To get rid of the scratches ordinary car polish should work.
