Hi all.
I've got a new hard-drive and I was wondering whether I should clone my current windows install or just format and start from scratch.
Normally I would just blank it and re-do it all but I've got a few apps on there that might be a bit tricky remembering exactly how to set them all up again.
If I were to 'clean' the disk instead of wipe it, how close do you think I could get it to a fresh install in terms of general snappiness?
All I use for cleaning currently is the windows defrag, ccleaner, and tunexp.
Thanks for any advice.
. I would image your current installation for backup purposes as well.
