Cleaning Walls...
10 Jan 2007
I know this is a pretty random thread, so sorry for all who were expecting a more exciting one(!), but I've got a very boring question about cleaning walls...
I want to clean a few parts on the walls of my bedroom. They are painted walls and usually (at home) I would just use a damp warm cloth and slowly rub the marks off, but at my Uni house the paint is painted ontop of wallpaper...
Does having paint ontop of wallpaper make a difference to how I should clean?
Cheers for any help and sorry for the most crappest thread!
I suppose dependent on the paint you have to be careful how much water you use, otherwise you might scrub off the paint, soak the wallpaper and have it peel off :p
If it is matt paint then I would not use a damp cloth. It could take off the paint. If it is a viynl silk paint then you are fine to wipe off with damp cloth. As far I know.
Good luck
