- 4 Nov 2003
- Edinburgh
What do you use to clean your bike after a long day?
I just want to make sure i'm looking after it and doing things right
Currently after a particularly heavy/gritty/muddy ride i'll visit a garage on the way home spray everything down, and then when home I take my chain off scrub with a chain cleaner (but i assume this could just be a general degreaser?) in the sink, but i'm also thinking of using an old bottle and just shaking it may do. I then spray the degreaser on the cassette, chainring and derailleur let it all dry and lightly oil and put it back on, to finish i degrease the discs just to make sure i didn't accidentally lube them up.
Is that too much/too little, what else could i be doing or leaving out? What stuff should i buy to do this, so far been using up stuff i've been bought but its branded (muc-off) and targeted (ie just chain cleaner!) so i assume i can just go out and buy any old 5l+ degreaser? What lubes should i be looking at?
I don't really want to be anal, but after spending some money doing my bike up i realised how much better it was riding, and i want to try and keep it like this for as long as possible, cassette/chain especially!
If anyone can share tips and experience i'd thank them
Currently after a particularly heavy/gritty/muddy ride i'll visit a garage on the way home spray everything down, and then when home I take my chain off scrub with a chain cleaner (but i assume this could just be a general degreaser?) in the sink, but i'm also thinking of using an old bottle and just shaking it may do. I then spray the degreaser on the cassette, chainring and derailleur let it all dry and lightly oil and put it back on, to finish i degrease the discs just to make sure i didn't accidentally lube them up.Is that too much/too little, what else could i be doing or leaving out? What stuff should i buy to do this, so far been using up stuff i've been bought but its branded (muc-off) and targeted (ie just chain cleaner!) so i assume i can just go out and buy any old 5l+ degreaser? What lubes should i be looking at?
) it mentioning being an all round performer so next time i clean replace chain lube with that? Dry make sense as it gets dusty muddy out here and my chain lube becomes a grinding paste, hence why i clean it alllll the time now...
