Cleaning your Mac stuff - iKlear ?
25 Apr 2004
Cambridgeshire UKJ
I'd like to keep my hardware nice and clean, can anyone recommend iKlear or similar products? I also have a nice Sony HDTV and the screen really needs a good clean, but the mrs is under strict orders not to touch it :p
Anti-Static Foam Cleaner.
Works wonders, and you don't have to worry where you spray it :)
Would that Anti-Static Foam Cleaner clean the actual laptop as well as the screen? (got a white Macbook)
Yes, it acts as a de-grease-er :)
I use it for cleaning all sorts of electrical equipment, and it does a very nice jobs of my MacBook Pro (screen + case)
Just normal foam cleaner that I might get from an office supplier perhaps? Or can someone point me to somewhere online to get something? :) My MacBook attracts every bit of dust from my room... :p
You might need a map to get to the electronics supplier I'm talking about.
I can't link directly because it's a competitor ;)
Even on the keyboard it's O.K.?
Yes, I use it on VERY expensive equipment at work everyday.
... we had a loan projector from Samsung that was £20,000 and it was OK (so I trust it on my MBP!!) :)
I've even sprayed some directly on live circuit boards (by accident!) in the past and I've never had any issues.
It has the bonus of keeping the dust away, whilst de-greasing so it's win win.
