Hi,
I think this would be the correct place to post this
I was just wondering what to use to clean my monitors ...
I have two U2412M's and I have a bottle of 'Anti Static Screen Cleaner' made by Dataform and some lint free tissues that came with it. These lint free tissues are really good to use with IPA and clean thermal paste but I find that they don't clean the screen very well, and leave streaks/marks with that spray
I just read on the internet and tried using a very slightly damp microfibre cloth (just damp with warm water) and this seems to do a really good job!
... But is it okay for the screen? I definitely don't want to cause any damage to them over time.
Obviously it wasn't dripping wet, was just slightly damp, enough to clean the screen and get rid of the mess made by the anti static cleaning spray. I could probably get away with a dry microfibre most of the time but it would be good to know if it is suitable to use a slightly damp microfibre without doing any harm
What are your views?
Thanks!
... But is it okay for the screen? I definitely don't want to cause any damage to them over time.Obviously it wasn't dripping wet, was just slightly damp, enough to clean the screen and get rid of the mess made by the anti static cleaning spray. I could probably get away with a dry microfibre most of the time but it would be good to know if it is suitable to use a slightly damp microfibre without doing any harm
Thanks!
