Cleaning
19 May 2006
hi,
i looked inside my comp the other day (6weeks old nd v.expensive) and i noticed that there is a fair amount of dust despite having 4fans. My question is this....how do i clean the dust out, can i just use a cloth because i am worried about static frying something important like my mobo.
Ty in advance
The dust is there because of your fans. Dunno about cleaning really, but get filters for your fans (or just use tights stretched over them) to reduce the amount of dust that builds up in your case.
More fans = more air = more dust
Canned air works best for me coz i'm lazy, and of course filters.
:cool: Hi,
I use Canned air and also a new dry paint brush for those hard stubben bits and that works a treat for me :D but dont foreget to switch the power off first at the mains before brushing inside the case :eek: :eek:
I don't use filters as their reduce air flow and increase temps in your case. ;)
paint brush, and theres some cleaner foam stiff that works like a mirical on the outside. as part of or com tech course we have to clean some pc's - makes sence i supose
