Cleaning...
31 Aug 2007
Guys, need to pick your brains...
I have a small mark (looks like a tiny piece of hair or something) on the inside of my 350D.
It's on the plastic piece that has the AF points marked on it, I don't know the name for it, but it's at the top of the camera if you look in from the front.
Now, I have blasted it loads with the Rocket Blower, and whilst it moved (further into the middle:rolleyes:) it is still there.
I then tried to remove it with a lint free cloth (for cleaning glasses) but it's still there and now I have a very small kind of cloudy area, obviously from where I wiped:rolleyes:
It's not affecting the images I am taking, but it is bloody annoying.
Is there anything I can do?
Any chemicals I need?
Or should I take it to a local photography shop and have them clean it?
Thanks in advance.
Never worry. I found a guide to remove and clean the part. It's actually the focusing screen.
Pretty easy to remove it actually, although even though I got rid of the worst mark, I think I left behind several smaller ones :rolleyes:
Will look to getting some more cleaning materials and have another bash.
Sorry to jump of your thread.
Where is the best place to take an SLR camera to have it's internal parts cleaned, like the mirror and such like?
I've got a few round marks that show up when using my wide angle lenses and with a long holiday coming up i'd like to get it cleaned before i go.
TIA
Can you share the link? I've got a friend with the same problem so it might be of use to him :)
Good pics here...
http://www.focusingscreen.com/work/400d.htm
And there's a very detailled write up here, for a 20D, but not much difference TBH...
http://doug.kerr.home.att.net/pumpkin/Replace_focusing_screen_20D.pdf
It's actually really easy to remove. Make sure you wear a pair of non-powdered surgical gloves though, as you will touch the mirror and this is the best way to keep skin oils off it.
Then simply set the camera upside down and bend the mirror buffer foam back to expose the small metal clip behind. It has a very small hole near the top of it, which you can insert something like a cocktail stick into.
Then push forward (VERY GENTLY) and lift up. The metal frame holding the screen in will lift up. Take it out.
Next thing I did was tip the camera slightly towards upright, until the screen begins to fall out. Take it out completely and you are ready to clean it.
Just watch that the small shim under the screen has remained in place. No drama if it hasn't, simply replace it. Although be really careful again, as it's very very thin.
Once you have the screen cleaned, replace the opposite way that you removed it. It is keyed and will only fit one way, so you can't go wrong.
Finally insert the metal frame again, making sure it doesn't get caught on the foam, and check that the side nearest you engages properly. If it doesn't, you may have bent it a little when removing. Again no drama, just take it back out and carefully bend it back straight again.
All done. Should take a minute to remove and refit, then however long you chose to clean it for.
If you figure a better way of cleaning it to make it 100% dust free, please let me know.
TIA
is it on the images or through the view finder?
if its just through the view finder its on the mirror/ focus screen
Is it only on the wide angle lens or all?
if yes, then it might be the lens.
do you notice it when the apeture is wide open (f/2.8-f/4) or just when the apeture is closed down (f/11+)
if its not apparent at wide open but there when closed down then the mark is on thte sensor.
hope that helps
On behalf of my friend, many thanks, he's now sorted it out and it was a great help to him, thanks for sharing :)
No worries at all. Sharing knowledge is what this place is all about.:) The link is fantastic, and credit to the author - great stuff!
Glad he got it sorted. I stripped mine today again and this time used laser lens cleaner and a sunglasses (lint free) cloth. It's now much, much better than before, and i'm more than happy with it.
