clear hdd
16 Mar 2007
hi,
is it possible to delete everything on the hdd, so that it is just hoow it is from a clean install. would like to do it WITHOUT formatting and reinstalling windows.
thanks
no
what you want to do is format & clean install, put drivers on etc, then take an image of the drive
after a few months of use if you want a fresh start, backup your work, then restore the image (ie, clean install again) and restore your work
acronis true image
