clear storm sniper side panel
7 Aug 2011
Northern Ireland
does anyone know where i can find a clear storm sniper clear side panel in the uk or europe that ships to the uk?
I have been searching everywhere...for weeks...
I don't think that there is one. There is none listed on Coolermaster's parts shop.
Time to do some modding of your own i think. How is the mesh fitted to your current sidepanel? Is it by little pushpins? If so it's easy enough to remove the mesh, cut a clear panel and fit it to the current side panel.
there is, if you check coolermaster usa, and they used to sell them here in europe, the mesh it just cut out of the panel, it cant be taken off.
i could buy the windowed haf 922 side panel but its just the window is rather small. the storm sniper side panel has a huge window and is the exact fit for the haf 922 except the thumbscrews dont line up which i can be fixed of course.
thanks anyway
also, would you know any us store that ships to europe?
thanks a lot, the postage is quite pricy - i will consider it if i dont see any others within the next week
For the price and time it would take to ship it, you'd be better off DIY. you just need some clear perspex, a jigsaw and some black screws
Lol I am using one with my HAF922. However I messed up the acrylic window and so am on the lookout for a new acrylic sheet which I am going to mod to exact shape and drill holes.
It did cost me around £34 as the shipping was £10 itself from netherlands :rolleyes:.
do you remember where you got it?
