- 26 Aug 2004
- Manchester
I've noticed a lot of the same questions being asked over and over again about this monitor. So, seeing as I have one I thought I'd have a go at giving them a definite answer.
I'd like to point out that this is only my opinion. If anyone thinks anything different to me, please post.
I've had this monitor few about 2 months now. It's my first TFT. Before this I had a 19" Hyundai ImageQuest Q995 CRT.
So without further ado:
Backlight Bleed: Looking at a black screen in a dark room there isn't any bleed. There's maybe a tiny patch in the top right, but it's not at all noticable.
Ghosting: None.
Resolution: The 1920x1200 res is perfect for this size screen. I sit probably about 3 feet away and text is clear and easily readable.
Gaming: I have an overclocked 6800GT, overclocked Athlon 64 3200+ and 1GB of GeIL RAM. Gaming at full res isn't a problem. I mostly play CS:S which I run with all settings high and 2xAA + AF. This gives me around 60FPS. Other more graphically intensive games normally run fine at medium settings.
Viewing Angels: If you can read text from looking at it side on, you'll be able to on this. But who uses monitors from the side anyway?
Banding: In desktop mode through DVI there's a very tiny amount. The only way you'd notice this in normal use is if you have a very smooth gradient as your background or maybe if you do a lot of work in Photoshop. The other modes (gaming and multimedia) show a bit more banding, but these seem a bit pointless anyway as desktop mode's fine.
Replacements: My first 2407 had 1 stuck pixel just off from the centre. I used if for a few weeks but my eyes were always drawn to it. I decided if I was paying this much for a monitor it should be perfect. Getting a replacement was a lot easier then expected. I just phoned Dell and asked to be put through to the monitor department. The guy on the other end was surprisingly helpful and arranged for a new monitor to be shipped out and the one I currently had to be collected shortly after. The only thing you'd have to be careful of it that you're being sent a new monitor as at first he was going to send a refurbished one. But it wasn't told this until after I asked whether I was getting a new one or not.
In Conclusion: Like I said, this is my first TFT. I'd never go back to a CRT now. The colours are more vibrant and it's so much clearer. I tried my CRT a couple of weeks ago and was amazed at the difference. It seemed tiny and everything was really blurred. I also have a much bigger display which takes up less room than my previous (smaller) one did. I couldn't recommend this monitor enough.
That's all I can think of for now. Any other questions or specific pictures wanted, let me know. I hope this helps some people.
Ghosting: None.
