Clevo Laptops help
22 Sep 2011
Hi. I am trying to help my grandmother find a laptop for about £500. The most important thing as far as she is concerned is build quality. The laptop likely won't be replaced for 5 years. She also wouldn't mind something that will survive away from the power source for an hour or so of light web browsing. The laptop will be used for e-mail, on-line banking, a crappy bridge program and maybe some iPlayer.
I have heard really good things about Clevo and just wanted to get some advice from you guys. I don't really know much about laptops. If I do decide to go with a Clevo, who are the best resellers?
The one that caught my eye was this one based on the Clevo w540eu and costs £530.
Chassis & Display: UltraNote: 14" Glossy HD LED Backlit Widescreen (1366x768)
Processor (CPU): Intel® Core™i3 Dual Core Mobile Processor i3-3120M (2.50GHz) 3MB
Memory (RAM): 4GB SAMSUNG 1600MHz SODIMM DDR3 MEMORY (1 x 4GB)
Graphics Card: Intel® HD Graphics 4000 Video Memory Technology up to 1.7GB
Memory - Hard Disk: 120GB INTEL® 520 SERIES SSD, SATA 6 Gb/s (upto 550MB/sR | 520MB/sW)
DVD/BLU-RAY Drive: Ultra Slim 8x SATA DVD±R/RW/Dual Layer (+ 24x CD-RW)
Memory Card Reader: Internal 9 in 1 Card Reader (MMC/RSMMC/SD: Mini, XC & HC/MS: Pro & Duo)
Sound Card: Intel 2 Channel High Definition Audio + MIC/Headphone Jack
Bluetooth & Wireless: GIGABIT LAN & WIRELESS INTEL® N-2230 (300Mbps) + BLUETOOTH
USB Options: 2 x USB 3.0 PORTS + 1 x USB 2.0 PORT AS STANDARD
Battery: UltraNote Series 6 Cell Lithium Ion Battery (62.16WH) (Up to 7 Hours)
Operating System: Genuine Windows 8 Standard Edition 64 Bit - inc DVD & Licence (£79)
Webcam: INTEGRATED 2.0 MEGAPIXEL WEBCAM
Thanks for the help
