Clicking Noise From PC
5 Dec 2008
Kent
Sorry but I have no video evidence of this. Will hopefully get my hands on an iPhone soon. I have youtubed it and seen clips of hard drives clicking. However, the noise coming from the PC doesn't sound like that.
I first thought that it was a loose screw that was bouncing around into fans but that is not the case. Sometimes it is silent and sometimes it is really noisy. I really am unsure about how to diagnose this. Does anyone have any advice?
Thanks.
Could be a fan coming a bit loose. Pop open the case, turn the PC on and lightly push the center of each fan to see if it stops the clicking.
My GPU fan clicks quite often, I fix it by pushing it in slightly.
I had a clicking noise problem a few months ago, give a listen to your power supply because it might be a capacitor clicking, that was the source of mine :P Other than that, just try as said above and stopping each fan individually or maybe booting up your PC with only different HDD's active?
Hope you solve your problem :)
Could be a cable hanging over a fan blade thats whacking off it? That used to happen to mine and a quick smack on the case made it go away for a while...
Yeah, I've had a look and that isn't the case.
I'll do the other advice when it starts again. It happens at random times.
Thanks.
Update: I can't see anything wrong inside the PC.
I would describe the noise as more of a rattling than a clicking.
If the noise is going on whilst the PC is shutting down, it continues when it is turned off and gradually gets slower which leads me to believe it could be a fan.
I don't mind a bit of soldering, just getting my hands on the correct replacement capacitor would be the real issue I think. Anyways thanks for the link, handy for future reference :)
