Client Side VB Script
18 Oct 2002
Yorkshire
having to do some work in client side vb script and i'm trying to work out how you check if a form element exists
e.g.
I've got a hidden field in a html form but this field is dynamically generated and might not exists. I need to check in the vbscript code to see if this hidden field is there or not.
At the moment when it doesn't exist i'm getting a "Object doesn't support this property or method..."
Any ideas on the syntax as theres not a great deal on the net :(
