Clip an AVI
29 Jul 2004
Glasgow/The Netherlands
I need to clip a section from an AVI, its only about 10 seconds i have to clip from a 10 minute file. Any free prgrams that will allow me to do this?
Thanks in advance
True.
virtualdub
set the video and audio to 'direct stream copy'
find the start of the 10 second clip, tap 'Home', then go to the end of it, and tap 'End', now tap F7 and you can save it
no converting is done, quality will be exactly the same :) (really quick process)
