Clock Interupt BSOD Help!!
6 Jul 2010
Felixstowe
Not sure if this is the right place, but here goes..
I have had this setup VVV working fine and I have stressed useing both overdrive and prime... had prime ran overnight and it ran well no problems..
However today for some reason I'm getting BSOD " A Clock Interupt was not received on a secondary processor within alocated time interval"..
So I ran Overdrive stability test again today for 3hrs and it worked fine..
After some tiddling about nothing to strenuous it crashed again with the above comment... this appears to be totally random and is starting to get on my nerves... I 'm running Win 7 enterprise any ideas!!
I did try a bit extra cpu vol, but it didn't seem to make any difference... During stress testing it holds up fine, just crashes out of nowhere with the above comment...
Well I'm going to try latest bios M4A88TD-M-EVO-ASUS-1404 see if that helps!!
If anyone is interested, I have read myself to death about this issue, and the general view appears to be a flaky core is responcible... this is a well known issue with the tri core cpu's that unlocked the 4th.. the 4th being the dodgy one it seems.. Some are even suggesting AMD have been cutting there losses selling bad 4 core CPUs as Tri Cores.. Well I dunno about all that, just hope the bios upgrade works for me!!:)
My friend had this issue years ago when the Phenoms first came out. Turned out a BIOS update solved the issue.
