Clock Keeps Hanging - Stops Folding
  • Thread starter Thread starter MGP
  • Start date Start date
MGP
MGP
24 Oct 2004
Surrey
Something is interrupting my PC's clock. After about an hour from resetting the clock, folding dies. :eek:
This is whether the PC is in use for other things, or not. It started some time on Saturday (before BST took any effect), and has continued. Rebooting the PC has no effect. The OS is fully patched, as are all drivers for GPU, etc. Clock is reset simply by clicking the "change time and date settings", and sychronsiing with the internet. I could understand a clock dropping it's time if the PC was off and the BIOS battery thing had failed, but with the PC on, that shouldn't be happening. Any thoughts please?
Windows 7 Pro, F@H 7.3.6, i7 2600K @ 4.6 (has been on this clock for weeks), MSI GTX 670 PE. All temps are in their normal ranges.
What does the folding log say? And are you sure the folding has actually stopped? Or is it that the folding doesn't know what to report without a clock to time against?
Folding uses UTC so it shouldn't care about the clock change.
typical example of the folding logs. Note the time skew detection is when I trigger a clock reset
Code:
01:54:59:WU01:FS00:0x15:Completed  19600000 out of 40000000 steps (49%).
00:57:15:WU01:FS00:0x15:Completed  20000000 out of 40000000 steps (50%).
******************************** Date: 01/04/13 ********************************
10:53:37:WARNING:WU01:FS00:Detected clock skew (9 hours 56 mins), adjusting time estimates
10:53:37:WARNING:WU00:FS01:Detected clock skew (9 hours 56 mins), adjusting time estimates
10:55:43:WU01:FS00:0x15:Completed  20400000 out of 40000000 steps (51%).
But allowing for the clock being wrong, does the folding program actually stop? Or is it still running? What does TaskManager show?
Taskmanager suggests that it is still running, but the logs aren't updating correctly and my PPD is way down so things aren't completing normally.
Whatever this weirdness is I suspect I'll have to do a reinstall on the PC as google is proving to be useless :(
Weird, Now that I've complained about it, it has been alright for a few hours :confused:
Change the CMOS battery. May not be the cause but worth trying.
I've just decommissioned my Z68 E4 G3 and it'll be in the mm very soon....
Spoke too soon. Been playing up again all evening. :(
Tried a windows restore point and that really threw a spanner in the works with the BST change. It completely screwed the antivirus amongst other things into thinking it was a different unlicenced version altogether. :confused:
Faulty BIOS battery wouldn't affect a PC that is powered up?
Not sure about this. I suspect the battery still runs the clock even when powered on so I'd change it anyway. If I remember correctly, the clock goes before the CMOS settings when the battery gets low.
I have replaced the battery, It's still doing it. Indeed the folding logs suggest the time actually jumps back an hour :confused:
Code:
*********************** Log Started 2013-04-03T18:36:16Z ***********************
18:36:16:************************* Folding@home Client *************************
18:36:16:      Website: http://folding.stanford.edu/
18:36:16:    Copyright: (c) 2009-2013 Stanford University
18:36:16:       Author: Joseph Coffland <[email protected]>
18:36:16:         Args:
18:36:16:       Config: D:/Folding/config.xml
18:36:16:******************************** Build ********************************
18:36:16:      Version: 7.3.6
18:36:16:         Date: Feb 18 2013
18:36:16:         Time: 15:25:17
18:36:16:      SVN Rev: 3923
18:36:16:       Branch: fah/trunk/client
18:36:16:     Compiler: Intel(R) C++ MSVC 1500 mode 1200
18:36:16:      Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
18:36:16:               /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
18:36:16:     Platform: win32 XP
18:36:16:         Bits: 32
18:36:16:         Mode: Release
18:36:16:******************************* System ********************************
18:36:16:          CPU: Intel(R) Core(TM) i7-2600K CPU @ 3.40GHz
18:36:16:       CPU ID: GenuineIntel Family 6 Model 42 Stepping 7
18:36:16:         CPUs: 8
18:36:16:       Memory: 7.89GiB
18:36:16:  Free Memory: 6.80GiB
18:36:16:      Threads: WINDOWS_THREADS
18:36:16:  Has Battery: false
18:36:16:   On Battery: false
18:36:16:   UTC offset: 1
18:36:16:          PID: 3312
18:36:16:          CWD: D:/Folding
18:36:16:           OS: Windows 7 Professional
18:36:16:      OS Arch: AMD64
18:36:16:         GPUs: 1
18:36:16:        GPU 0: NVIDIA:3 GK104 [GeForce GTX 670]
18:36:16:         CUDA: 3.0
18:36:16:  CUDA Driver: 5000
18:36:16:Win32 Service: false
18:36:16:***********************************************************************
18:36:16:<config>
18:36:16:  <!-- Folding Slot Configuration -->
18:36:16:  <extra-core-args v='-advanced'/>
18:36:16:  <power v='full'/>
18:36:16:
18:36:16:  <!-- Network -->
18:36:16:  <proxy v=':8080'/>
18:36:16:
18:36:16:  <!-- User Information -->
18:36:16:  <passkey v='********************************'/>
18:36:16:  <team v='10'/>
18:36:16:  <user v='Borged_by_MGP'/>
18:36:16:
18:36:16:  <!-- Folding Slots -->
18:36:16:  <slot id='0' type='GPU'>
18:36:16:    <next-unit-percentage v='95'/>
18:36:16:  </slot>
18:36:16:  <slot id='1' type='CPU'>
18:36:16:    <cpus v='-1'/>
18:36:16:  </slot>
18:36:16:</config>
18:36:16:Trying to access database...
18:36:16:Successfully acquired database lock
18:36:16:Enabled folding slot 00: READY gpu:0:GK104 [GeForce GTX 670]
18:36:16:Enabled folding slot 01: READY cpu:8
18:36:16:WU01:FS01:Starting
18:36:16:WU01:FS01:Running FahCore: D:\Folding/FAHCoreWrapper.exe D:/Folding/cores/www.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 01 -suffix 01 -version 703 -lifeline 3312 -checkpoint 15 -np 8 -advanced
18:36:16:WU01:FS01:Started FahCore on PID 4124
18:36:16:WU01:FS01:Core PID:4136
18:36:16:WU01:FS01:FahCore 0xa4 started
18:36:16:WU02:FS00:Starting
18:36:16:WU02:FS00:Running FahCore: D:\Folding/FAHCoreWrapper.exe D:/Folding/cores/www.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_15.fah/FahCore_15.exe -dir 02 -suffix 01 -version 703 -lifeline 3312 -checkpoint 15 -gpu 0 -gpu-vendor nvidia -advanced
18:36:16:WU02:FS00:Started FahCore on PID 4144
18:36:16:WU02:FS00:Core PID:4156
18:36:16:WU02:FS00:FahCore 0x15 started
18:36:17:WU01:FS01:0xa4:
18:36:17:WU01:FS01:0xa4:*------------------------------*
18:36:17:WU01:FS01:0xa4:Folding@Home Gromacs GB Core
18:36:17:WU01:FS01:0xa4:Version 2.27 (Dec. 15, 2010)
18:36:17:WU01:FS01:0xa4:Preparing to commence simulation
18:36:17:WU01:FS01:0xa4:- Ensuring status. Please wait.
18:36:17:WU02:FS00:0x15:
18:36:17:WU02:FS00:0x15:*------------------------------*
18:36:17:WU02:FS00:0x15:Folding@Home GPU Core
18:36:17:WU02:FS00:0x15:Version                2.25 (Wed May 9 17:03:01 EDT 2012)
18:36:17:WU02:FS00:0x15:Build host             AmoebaRemote
18:36:17:WU02:FS00:0x15:Board Type             NVIDIA/CUDA
18:36:17:WU02:FS00:0x15:Core                   15
18:36:17:WU02:FS00:0x15:Window's signal control handler registered.
18:36:17:WU02:FS00:0x15:Preparing to commence simulation
18:36:17:WU02:FS00:0x15:- Ensuring status. Please wait.
18:36:26:WU01:FS01:0xa4:- Looking at optimizations...
18:36:26:WU01:FS01:0xa4:- Working with standard loops on this execution.
18:36:26:WU01:FS01:0xa4:- Previous termination of core was improper.
18:36:26:WU01:FS01:0xa4:- Files status OK
18:36:26:WU02:FS00:0x15:- Looking at optimizations...
18:36:26:WU02:FS00:0x15:- Working with standard loops on this execution.
18:36:26:WU02:FS00:0x15:- Previous termination of core was improper.
18:36:26:WU02:FS00:0x15:- Files status OK
18:36:26:WU02:FS00:0x15:sizeof(CORE_PACKET_HDR) = 512 file=<>
18:36:26:WU02:FS00:0x15:- Expanded 126720 -> 507182 (decompressed 400.2 percent)
18:36:26:WU02:FS00:0x15:Called DecompressByteArray: compressed_data_size=126720 data_size=507182, decompressed_data_size=507182 diff=0
18:36:26:WU02:FS00:0x15:- Digital signature verified
18:36:26:WU02:FS00:0x15:Project: 7626 (Run 595, Clone 0, Gen 56)
18:36:26:WU02:FS00:0x15:Entering M.D.
18:36:26:WU01:FS01:0xa4:- Expanded 545224 -> 842528 (decompressed 154.5 percent)
18:36:26:WU01:FS01:0xa4:Called DecompressByteArray: compressed_data_size=545224 data_size=842528, decompressed_data_size=842528 diff=0
18:36:26:WU01:FS01:0xa4:- Digital signature verified
18:36:26:WU01:FS01:0xa4:Project: 7646 (Run 33, Clone 0, Gen 121)
18:36:26:WU01:FS01:0xa4:Entering M.D.
18:36:28:WU02:FS00:0x15:Will resume from checkpoint file 02/wudata_01.ckp
18:36:28:WU02:FS00:0x15:Tpr hash 02/wudata_01.tpr:  2600584506 2223309731 398929267 2652468244 672599459
18:36:28:WU02:FS00:0x15:GPU device id=0
18:36:29:WU02:FS00:0x15:Working on Protein
18:36:29:WU02:FS00:0x15:Client config unavailable.
18:36:29:WU02:FS00:0x15:Starting GUI Server
18:36:32:WU01:FS01:0xa4:Using Gromacs checkpoints
18:36:32:WU01:FS01:0xa4:Mapping NT from 8 to 8
18:36:33:WU01:FS01:0xa4:Resuming from checkpoint
18:36:33:WU01:FS01:0xa4:Verified 01/wudata_01.log
18:36:34:WU01:FS01:0xa4:Verified 01/wudata_01.trr
18:36:34:WU01:FS01:0xa4:Verified 01/wudata_01.xtc
18:36:34:WU01:FS01:0xa4:Verified 01/wudata_01.edr
18:36:34:WU01:FS01:0xa4:Completed 1609480 out of 2500000 steps  (64%)
19:13:08:WARNING:WU01:FS01:Detected clock skew (36 mins 16 secs), adjusting time estimates
19:13:47:WU02:FS00:0x15:Resuming from checkpoint
19:13:47:WU02:FS00:0x15:fcCheckPointResume: retreived and current tpr file hash:
19:13:47:WU02:FS00:0x15:   0   2600584506   2600584506
19:13:47:WU02:FS00:0x15:   1   2223309731   2223309731
19:13:47:WU02:FS00:0x15:   2    398929267    398929267
19:13:47:WU02:FS00:0x15:   3   2652468244   2652468244
19:13:47:WU02:FS00:0x15:   4    672599459    672599459
19:13:47:WU02:FS00:0x15:fcCheckPointResume: file hashes same.
19:13:47:WU02:FS00:0x15:fcCheckPointResume: state restored.
19:13:47:WU02:FS00:0x15:fcCheckPointResume: name 02/wudata_01.log Verified 02/wudata_01.log
19:13:47:WU02:FS00:0x15:fcCheckPointResume: name 02/wudata_01.trr Verified 02/wudata_01.trr
19:13:47:WU02:FS00:0x15:fcCheckPointResume: name 02/wudata_01.xtc Verified 02/wudata_01.xtc
19:13:47:WU02:FS00:0x15:fcCheckPointResume: name 02/wudata_01.edr Verified 02/wudata_01.edr
19:13:47:WU02:FS00:0x15:fcCheckPointResume: state restored 2
19:13:47:WU02:FS00:0x15:Resumed from checkpoint
19:13:47:WU02:FS00:0x15:Setting checkpoint frequency: 400000
19:13:47:WU02:FS00:0x15:Completed  10400001 out of 40000000 steps (26%).
19:13:48:WARNING:WU02:FS00:Detected clock skew (37 mins 22 secs), adjusting time estimates
19:18:38:WU02:FS00:0x15:Completed  10800000 out of 40000000 steps (27%).
19:21:39:WU01:FS01:0xa4:Completed 1625000 out of 2500000 steps  (65%)
19:23:29:WU02:FS00:0x15:Completed  11200000 out of 40000000 steps (28%).
19:28:18:WU02:FS00:0x15:Completed  11600000 out of 40000000 steps (29%).
19:33:08:WU02:FS00:0x15:Completed  12000000 out of 40000000 steps (30%).
19:34:54:WU01:FS01:0xa4:Completed 1650000 out of 2500000 steps  (66%)
19:37:58:WU02:FS00:0x15:Completed  12400000 out of 40000000 steps (31%).
19:42:47:WU02:FS00:0x15:Completed  12800000 out of 40000000 steps (32%).
19:47:37:WU02:FS00:0x15:Completed  13200000 out of 40000000 steps (33%).
19:49:41:WU01:FS01:0xa4:Completed 1675000 out of 2500000 steps  (67%)
19:52:26:WU02:FS00:0x15:Completed  13600000 out of 40000000 steps (34%).
19:57:15:WU02:FS00:0x15:Completed  14000000 out of 40000000 steps (35%).
20:02:05:WU02:FS00:0x15:Completed  14400000 out of 40000000 steps (36%).
20:02:52:WU01:FS01:0xa4:Completed 1700000 out of 2500000 steps  (68%)
20:06:55:WU02:FS00:0x15:Completed  14800000 out of 40000000 steps (37%).
20:11:45:WU02:FS00:0x15:Completed  15200000 out of 40000000 steps (38%).
19:16:48:WU01:FS01:0xa4:Completed 1725000 out of 2500000 steps  (69%)
18:36:16:         Args:
18:36:16:         Bits: 32
18:36:16:         CPUs: 8
18:36:16:          PID: 3312
18:36:16:         GPUs: 1
18:36:16:         CUDA: 3.0
18:36:16:<config>
18:36:16:
18:36:16:
18:36:16:
18:36:16:  </slot>
18:36:16:  </slot>
18:36:16:</config>
19:17:24:WU02:FS00:0x15:Completed  15600000 out of 40000000 steps (39%).
19:22:13:WU02:FS00:0x15:Completed  16000000 out of 40000000 steps (40%).
18:36:16:         Args:
18:36:16:         Bits: 32
18:36:16:         CPUs: 8
18:36:16:          PID: 3312
18:36:16:         GPUs: 1
18:36:16:         CUDA: 3.0
18:36:16:<config>
18:36:16:
18:36:16:
18:36:16:
18:36:16:  </slot>
18:36:16:  </slot>
18:36:16:</config>
[COLOR="Yellow"]20:11:45[/COLOR]:WU02:FS00:0x15:Completed  15200000 out of 40000000 steps (38%).
[COLOR="Yellow"]19:16:48[/COLOR]:WU01:FS01:0xa4:Completed 1725000 out of 2500000 steps  (69%)
[COLOR="Yellow"]19:17:24[/COLOR]:WU02:FS00:0x15:Completed  15600000 out of 40000000 steps (39%).
20:25:53:WARNING:WU01:FS01:Detected clock skew (59 mins 11 secs), adjusting time estimates
20:25:53:WARNING:WU02:FS00:Detected clock skew (59 mins 11 secs), adjusting time estimates
20:26:13:WU02:FS00:0x15:Completed  16400000 out of 40000000 steps (41%).
20:29:12:WU01:FS01:0xa4:Completed 1750000 out of 2500000 steps  (70%)
20:31:05:WU02:FS00:0x15:Completed  16800000 out of 40000000 steps (42%).
20:35:55:WU02:FS00:0x15:Completed  17200000 out of 40000000 steps (43%).
ive had this, i just fully removed folding and downloaded it again, i checked my logs to see if there was anything but there isnt anything now
Heh, its just thats the only time I've had experience of it happening on any of my rigs. The VM's sometimes lost track of time.
Hmm, whatever has happened appears to have broken the BIOS clock. Even with the PC powered off for a while the BIOS screen clock stays stuck on the time at last shutdown, and doesn't update even whilst the BIOS screen is running :(
Might be making a tiny bit of progress. Although I'd previously replaced the CMOS battery, and I've uploaded the latest BIOS, both of which reset some BIOS stuff like the HDDS went from AHCI to IDE incorrectly, not everything reset. A hard CMOS /BIOS reset with the motherboard jumpers has sprung the BIOS clock back into life, at the expense of all my overclock settings. One step forward, one back ....
